There are two tables created when loading RGP file into the user defined table, one for liquid and other for vapor. Which table to select when using TUI command to use RGP table for wet steam model.
March 17, 2023 at 8:59 am
FAQParticipantWhen creating RGP tables for wet steam, it would be sufficient to generate it for the vapor component, as this will contain all the necessary information required by the model. Hence, it would take in the vapor table for the simulation. Keywords: RGP, table, wet steam, TUI, command, vapor, Fluent
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
