The ‘Optimization’ component has question mark in it despite Number of initial samples greater than enabled parameters. If I click on blue triangle, it gives error “Number of Initial Samples and or Number of Samples per Iteration set to value smaller than total enabled parameters”
Tagged: 19.2, General, structural-mechanics, workbench platform
April 5, 2023 at 2:32 pm
FAQParticipantAll the derived parameters are already “enabled” in Optimization. In the Results, if you check the ‘Samples’ option shows all the enabled input and output parameters which also includes derived input and output parameters. ANSYS Help file indicates that Initial Samples should be equal to or greater than enabled input & output parameter. While Number of Samples/Iteration should be equal to or less than Initial Samples. But this can not be less than total enabled input & output parameters.
