The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
Tagged: ls-dyna, LS-DYNA Suite, lsdyna, R12, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantPlease use construction stages keyword options, Have a look at the following keywords: *DEFINE_CONSTRUCTION_STAGES *DEFINE_STAGED_CONSTRUCTION_PART *CONTROL_STAGED_CONSTRUCTION With these keywords, you can define stages and add or remove parts at different stages during the analysis. Please find attached one sample example for your reference
