The heat of vaporization is usually given in J/kg. The other SI derived unit is in Joule per mole or Joule per kilomol ( kmol or kgmol) which is used by ANSYS Fluent. How can I convert my input so that it might be used in ANSYS Fluent?
Tagged: 2019 R1, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQParticipantIn ANSYS Fluent the dimension of the molecular weight is expressed in kg/kmol (kg/kgmol = kg per 1000 moles). So to get the correct input of heat of vaporization or in general the standard state enthalpy of particular fluid at a reference temperature for Fluent the conversion below is required: standard state enthalpy in [J/kg]* Molar Mass [kg/kgmol] = Latent Heat in [J/kgmol ] Keywords: Latent Heat, kg/kmol, molecular weight
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
