The following error happens after re-partitioning during a System Coupling FSI run. How can this be prevented? Error at Node 2: alloc_thread_sv: storage already exists for SV_WALL_FACE_FORCE on thread 11, domain 2
Tagged: 2021 R1, fluent, fluid-dynamics, fsi, Modeling/Setup Advice
March 17, 2023 at 8:59 am
FAQ
ParticipantThis issue has been fixed for 2021R2. The workaround for earlier versions is to turn off re-partitioning. To do this, in Fluent go to Parallel tab > Partition/Load Balance > Dynamic Load Balancing tab > turn off Dynamic Mesh. Zone remeshing will also need to be turned off with the following tui command: /define/dynamic-mesh/controls/remeshing-parameters/zone-remeshing no
- Skewness in ANSYS Meshing
