The curvilinear element used in HFSS Eigenmode solver leads to this message “failure in matrix solver”
Tagged: 16, Electromagnetics & Electronics, General (HFSS), hfss, Other
May 25, 2023 at 7:29 am
FAQParticipantCurvilinear elements can cause problems in the case of complex geometry and to find the nearest true surface might not be unique. To deal with this issue, it is recommended to increase the number of segmentation of the curvilinear element and it will work fine. One advice: at the same time, decrease Aspect ratio. I used aspect ratio=3. It results in a better quality mesh. Usually, Eigenmode problems are very sensitive to the mesh quality. My setting was 10 degrees with aspect ratio = 3
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
