The CFX solver does not start when a variable expression is used for defining the injection radius in a Particle Injection Region.
June 5, 2023 at 7:05 am
FAQParticipantThis can be resolved by copying the lines: RULES: PARAMETER: Outer Radius of Injection Plane Dependency List = t Single Valued = true END PARAMETER: Inner Radius of Injection Plane Dependency List = t Single Valued = true END END into a file, e.g. rules_pir.ccl, and starting the solver with the solver option: -ccl rules_pir.ccl
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
