May 25, 2023 at 7:29 am
FAQParticipantError message ‘TDSlink application has stopped working’ indicates that the external circuit is created with an earlier Maxwell/Electronics Desktop version. To overcome the problem, please re-create the external circuit using the same Electronics Desktop version you use for your simulations.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
