Tagged: ansys-student, ansys-workbench, Structual Analysis
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantThis video introduces basic steps required to solve the FEA problem using ANSYS Static Structural. From the beginning to 4:50, you will learn how to import geometry, apply materials & use multizone method to generate the quality mesh. From 4:50 to the end, you will learn to apply BCs and post-process the results to find out maximum stress and deformation. Learn more at http://www.ansys.com/studentcommunity
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/Ansys-Cloud.jpeg)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Optical-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/03/Geko_Video-1-1.png)
![](https://innovationspace.ansys.com/knowledge/wp-content/uploads/sites/4/2022/06/EnSight_PP.webp)
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
