Tagged: 3d printing, repair, spaceclaim, SpaceClaim App Example, stl
September 26, 2022 at 9:59 am
Watch & LearnParticipantThe STL Prep for 3D Printing module helps you repair 3D printing issues — like water-tightness, wall thickness and self-intersecting triangles– as easily as you clean up bad geometry today. The module also provides all of the solid creation and editing tools SpaceClaim is famous for so that users can directly edit STL and solids in the same solution
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
