General
General
stl file export is not available anymore in Fluent Meshing from R18.2
    • FAQFAQ
      Participant
      stl file export works only on serial mode From R18.2 onwards, when you run “serial” Fluent Meshing, it is actually run as a parallel process on 1 proc. To force the serial behavior (and therefore access the /file/export/stl text command), select ‘Parallel’ in the Fluent launcher, and choose 0 process
