April 5, 2023 at 2:31 pm
FAQParticipantSolution: Found out that it was an installation issue. The old SpaceClaim Engineer was mixed up with an ANSYS Installation which leads to problems of the interface and program start. De-installing ANSYS and SpaceClaim Engineer. Running a registry cleaner, delete the version folder in the ANSYS roaming folder (%appdata%) and a new installation of ANSYS solves the problem.
