June 5, 2023 at 7:05 am
FAQParticipantSymptom: The ANSYS SpaceClaim geometry can’t be imported and the message “Update failed for the Model component…” is shown. Solution: Please check your geometry model for your “Activated for Physics” geometries. If all geometries are “Suppressed for Physics” – (crossed circle in the upper right corner) nothing is send to the workbench. As consequence the attach fails.
