September 26, 2022 at 9:59 am
Watch & LearnParticipantSpaceClaim can be used for additive manufacturing or rapid prototyping engineering process. This video shows how quick and easy the tool is to use slice & dice method to split your geometry into smaller solids that will fit into your build envelope as well as creating lap joints to easily fit these solids back together after printing.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- FAQ: Missing Areas of the User Interface in Discovery Live
