Sometimes the error message “Unexpected error while refreshing view files: The given key was not present in the dictionary.” occurs in the project schematic. What can I do?
Tagged: 16.1, General, structural-mechanics, workbench platform
March 17, 2023 at 9:00 am
FAQ
ParticipantDelete all temporary data in %APPDATA%Ansysv160 and %TEMP%.ansys not just %APPDATA%
