Slow performance for serial runs on Dual Quadcore machines. No other jobs are running on this machine. Parallel performance is poor.
March 17, 2023 at 9:01 am
FAQParticipantMain reason for this was in this case the main board. In both cases the customer had a Tyan board. One customer changed a board from Tyan to Supermicro and the performance improved about a factor of 1.9. I added here the hardware vendors of the boards although I know this behavior can change in the future. The knowledge about the hardware components should be at the hardware vendor side, but this is not always the case. The HP distributor did not know about High Performance Computing. In our case Michael Ehrig from HP High Performance Center identified immediately the board as reason. Dual Quadcore machines become more and more usual. Customers have to be aware that hardware is more than the processor and maybe benchmarks are necessary before ordering machines.
