Tagged: 16.1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 amFAQParticipant
The scheme function provided below creates a file named ‘flow-time-xyz’. Here ‘xyz’ is the value of flow time. For example, if the flow time is 0.0037 seconds then the file name would be ‘flow-time-0.0037’. Current scheme only saves the value of flow time in the file ‘flow-time-xyz’ as an example but this can be changed as needed. ; This scheme function will create a file “flow-time-xyz” ; “xyz” is the current value of flow time in seconds ; Currently this function just appends the current flow time value in this file as an example ; It can be modified according to the use case ; To call this function write (fn1) in Solve-> Execute Commands panel ; We can change filename by changing the value of variable ‘name’. (define (fn1) ; Change file name as needed (define name “flow-time-“) (define fullname (string-append name (number->string (rpgetvar ‘flow-time)))) (append-file fullname ‘(lambda(port)(format port “~an” (rpgetvar ‘flow-time)))))
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
