September 26, 2022 at 9:33 am
FAQParticipantThe User settings in Discovery SpaceClaim and Discovery Live might require frequent alterations to cater to the modelling requirements such as change of units type or change of drawing sheet detailing etc.
The below steps will guide you to export and import your user settings from different versions or different sessions of Discovery SpaceClaim so that it is convenient and does not have to be manually changed each time.
- Go to ‘SpaceClaim/Live options’ from ‘File’ in Discovery SpaceClaim or Discovery Live.
- Under ‘Advanced’, on the right side, you have ‘Export User Settings'(refer image). Clicking on this will create a ‘user.config’ file.
- Open Discovery SpaceClaim/Live and again in ‘SpaceClaim/Live options’ > ‘Advanced’, click on ‘Import user settings’ (refer image) and choose the ‘user.config’ file saved in the previous step.
You may have to re-start Discovery SpaceClaim/ Live for the settings to apply.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
