January 25, 2023 at 7:28 am
FAQParticipantMSMPI can be run standalone as follows: The following environment variables must be set (use a real host name in place of
and use the actual MSMPI installation path for MSMPI_BIN): set _CFX_ENABLE_MSMPI_SM=1 set MSMPI_BIN=C:Program FilesMicrosoft MPIBin set CCP_NODES=1 2 The MSMPI daemon must be running, or this may be started manually for testing using the command (full path to smpd): smpd -d 1 The solver may then be started using: cfx5solve -def StaticMixer.def -par-local -part 2 -start-method MSMPI It’s quite likely that in a future release we will provide MSMPI as a standalone start method on Windows.
