September 26, 2022 at 9:53 am
FAQParticipantProblem: While trying to launch any Discovery application, the following error is encountered in some cases.
Error:
Unexpected HttpRequestException from ANSYS Cloud API trying to connect.
URL https://subscription-api.ansys.com/api/v1/
Error Response status code does not indicate success: 500 (Internal Server Error).
Cause: It has been noticed that this error occurs when a user tries to activate and launch Discovery applications when the cloud server is temporarily down.
Recommended Solution: To overcome this issue, please wait for some time and then try launching Discovery application again.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- Discovery Subscription license – Command line options
- ANSYS Discovery: Compatibility Utility
