September 26, 2022 at 9:58 am
FAQParticipantProblem: When opening Discovery SpaceClaim 2019 R2 via enterprise (floating) license, you may receive one of the following license errors:
Error message1: If you are still running the 2019 R1 License Manager, you will see below error:
Request name 16064 does not exist in the licensing pool.
Error message2: If you are still running the 2019 R2 License Manager, you will see below error:
Capability ANSYS Additive Prep does not exist in ANSYS licensing pool.
Cause: This error is a known issue we have seen with the 2019R2 product. SpaceClaim will still open after clicking OK.
Recommended Solution: If you are still using ANSYS License manager version 2019 R1, please update it to 2019 R2. Next, to stop this error from popping up, once in SpaceClaim, go to File->SpaceClaim Options->Add-Ins and uncheck Additive add-in.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- How to setup a Parameter Study
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
