Tagged: Ansys Discovery, installation, Installation-FAQ
September 26, 2022 at 9:53 am
FAQParticipantProblem: After installing discovery products, when launched an error stating “The application cannot be run at this time because the ENABLE_ANSYS_QA_SERVICES environment variable is enabled. This application is not supported in the scope of an ANSYS QA Services agreement” is displayed.
Cause: This happens when the ‘Enable QA services with supported applications’ option is selected during installation, and Discovery products are not a supported application in the scope of QA services agreement yet.
Recommended solution: Please open the Environment Variables in the control panel (Control Panel>System and Security>System>Advanced system settings>Environment variables) and check if there is any variable named “ENABLE_ANSYS_QA_SERVICES” and delete it.
If the above environment variable is not available, then the user will have to uninstall and reinstall Discovery again, while making sure the ‘Enable QA services with supported applications (QA services agreement required)’ option is deselected and then proceed with the installation. (Refer to below image).
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
