Tagged: 19.2, fluent, fluid-dynamics, General, General - FLUENT, parallel
January 25, 2023 at 7:16 am
FAQParticipant1) from v18.x onwards, while loading any mesh or case file, the domain reordering is automatically called to reduce the bandwidth of the existing case 2) this feature is available only with the parallel versions of ANSYS Fluent, and not serial solver
- Skewness in ANSYS Meshing
