R2019-R2 Additive Print hangs while loading files and /or defining properties. R2019-R3 installed on same machine does not have this problem. Why?
April 5, 2023 at 2:31 pm
FAQParticipantWhen you install a newer version on the same machine as an older version using the same path locations, it updates the databases to the new version. They cannot be reverted to the old version. As such 2019 R2 cannot load all of the 2019 R3 database structures (since the database changes each version).
