Question: How do I fix Spaceclaim crashing on start with an unhandled Microsoft .NET Framework exception occurred in SpaceClaim.exe [2288]?
August 25, 2023 at 12:16 pm
SolutionParticipantAnswer: Please refer to the attachments to access the Solution.
1. 2048603.pdf
