May 15, 2023 at 8:33 am
SolutionParticipantA: You can select faces from one body using the following steps: – Create one Named selection including the selected Body Then create a Worksheet with these lines: – Add Body from Named Selection – Convert body to Faces Attached you can find an example
1. 2054787.zip
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
