Tagged: 18.2, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, particle, post-processing
May 15, 2023 at 8:32 am
Solution
ParticipantA new expert parameter was introduced in CFX-Pre 18.2 to write the particle mass flow variable to the res file so that it is available in CFD-Post. The parameter is: pt force export massflow = t Instructions for setting this parameter are attached.
1. 2052304.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
