POLYFLOW: Error for calculations with UDF (User defined functions): “CLIPS data structures are in an inconsistent or corrupted stateâ€
March 17, 2023 at 8:58 amFAQParticipant
A calculation with a UDF produces the following error message: “CLIPS data structures are in an inconsistent or corrupted state. This error may have occurred from errors in user defined code.” What can be done? It is possible that the evaluation of the function has failed. This may happen when the argument leads for example to a numerical overflow. A typical case is when the UDF involves an unbounded function like exp, cosh etc. Here, the value of the argument of the UDF invoked should be checked.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
