General
General
POLYDATA: How can one easily run a Blow molding/Thermoforming case with KBKZ model at another temperature without re-entering all material data?
    • FAQFAQ
      Participant
      The user wishes to run many isothermal thermoforming simulations with the KBKZ model, each at a different sheet temperature. A fact is that all parameters are affected by the shift factor. How can this be easily done in POLYDATA without re-entering all material data? A reasonable approach consists of defining a non-isothermal simulation with all required data. In particular, the temperature dependence of the properties has to be specified (say using multi-ramp functionality using PMAT with field set to Temperature). Under those circumstances, for running the application at a given (constant) temperature, the user may specify this temperature as initial data and ask a decoupled velocity/temperature calculation. By doing so, the material parameters will be properly adjusted. It is important to note that temperature boundary conditions should be of the type “insulated” only, that the mold must be adiabatic and that relevant material parameters (thermal conductivity and heat capacity) have to be defined for the energy equation. Failing to do so may affect the results.
