General
General
Parametric sweep exits with error message: Parametric setup1- Invalid solution selection for goal calculation: No solution data
    • SolutionSolution
      Participant
      This error message indicates that the entry in Calculation Tab of parametric sweep setup can not be evaluated for some reason. Usually that happen after the user modifies the setup without checking how the modifications affect the parametric sweep options. For example, the user changed the Analysis setup frequency without changing Parametric sweep options. Figure 1 illustrates this case. Note, the red cross sign next to the entries to indicate the mismatch. To fix this issue, it is necessary to delete entries in the Calculation Tab or change the Calculation Range to match the Analysis Setup. To resolve the error, it is necessary to check that all the entries Calculation Tab of parametric sweep exist in the design, and that the calculation ranges match the design options. The most frequent settings to check are in Analysis setup and Infinite Sphere Setup.
      1. 2043114.pdf
