Parallel run does not start because connection to machine fails, although its hostname mas34xxx.local is entered in the host.ccl file. Why?
March 17, 2023 at 8:58 amFAQParticipant
The hostnames in the host.ccl file have to follow some rules. They must not contain points ‘.’ or underscores ‘_’ and they must start with a character. So the hostname of this machine has to be changed.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
