March 17, 2023 at 9:00 amFAQParticipant
Running too many tasks in Windows service may result in run time errors – due the desktop heap limit. Reduce the number of tasks or increase the heap size to 3072 kilo bytes. Use regedit to modify HKLMSYSTEMCurrentControlSetControlSession ManagerSubSystemsWindows change: SharedSection=1024, 20480,768 to: SharedSection=1024, 20480,3072
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
