Tagged: 2019 R2, Dense DPM, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase
January 25, 2023 at 7:17 am
FAQParticipantDDPM model can only interact with the primary Eulerian phase. The momentum exchange terms from particle tracking are considered only in the primary phase momentum equations. Although the solver setup allows you to enable more than one Eulerian phases with the DDPM model, the solution will not capture the particle phase interactions with the dispersed (other secondary) Eulerian phases. For example, consider a simulation involving dense solid particles in a water continua which also has gas sparged from the bottom; where the phases are setup as below: – Primary phase: Water – Secondary (Eulerian) phase: Gas – Discrete phase (DDPM): Solid-particles If solid-particles and gas bubbles end up in the same computational cell, the effect of particles on bubbles and vice-versa will not be captured.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
