General
General
On setting the Time larger than 1.0, how does time effect the total load applied, would the load be scaled to 4x at time=4.0?
    • FAQFAQ
      Participant
      The value used for time in a static analysis has no effect other than differentiating the load steps. In a transient analysis, time dependent loads like velocity and acceleration do include time effects. The value of time is never used to scale a load in static analysis. But it will affect the results in transient analyses. In the substep calculations. the change in time over a load step is used.
