September 26, 2022 at 9:53 am
SolutionParticipantWe have become aware of an issue with using subscription licenses while not connected to the internet. The licensing for Discovery 19.1 products may fail the day after disconnecting an activated machine from the internet. A hotfix for this issue is available, and existing Discovery 19.1 installations can be patched with the following instructions.
- Download the attached ansysls_client_exe.txt file, and rename it to ansysls_client.exe.
- Replace the existing ansysls_client.exe file in C:Program FilesANSYS IncShared FilesLicensingwinx64 with this new version.
- Restart your Discovery software while connected to the internet.
We apologize for any inconvenience this issue may cause. An updated 19.1 product installation with the fix included will be posted shortly.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
