Named selections created in SpaceClaim Direct Modeler do not show up in Mechanical/Meshing applications.
June 6, 2022 at 9:58 am
FAQParticipantIn SpaceClaim Direct Modeler, Groups tab, see if the Named Selections all show up with using “View groups in” is set to “Root Part”. If groups are created for active parts, then these component groups should be imported to the root part. To do this, right click on the component and select “Import Component Groups”. Then update the geometry in the Mechanical / Meshing application
