May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim can be used to extract mid surface for performing structural analysis. Attached video demonstrates one such example of mid surface extraction and extending the mid surfaces to connect with each other for sharing topology Keywords: mid surface, extend, share topology
1. 2052805.zip
2. 2052805_Captions-EN.mp4
