Maxwell results deleted on project save. Running Maxwell inside ANSYS Workbench and using the background white space properties update option, Submit to Remote Solve Manager.
March 17, 2023 at 2:15 pm
FAQParticipantA Maxwell calculation run inside Workbench using the background white space properties option: “Submit to Remote Solve Manager” will delete all Maxwell results files when the project is saved. This is how the software is currently designed to work when using the ANSYS Remote Solve Option (RSM). Only the Design Point/DX output data is retained. If you want to retain the Maxwell results files, change the background white space properties option to: “Run in Foreground”.
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- Cloud Computing from Electronics Desktop
- How to create and manage a queue of simulations?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Are solid losses and eddy losses the same in Maxwell?
- Parameters in HFSS 3D Components and design level variables
