LS-DSO Dataset Import: Error message ‘No res1d files are found under folder ‘XX’, solution cannot be imported’
March 17, 2023 at 2:15 pm
FAQParticipantWhen importing LS-DSO dataset results, select the folder project.aedtresults/
. Leave the Solution Name as it is, and importing will work. If you select any of the subfolders, the import will not work.
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
