October 17, 2025 at 12:08 pm
SolutionParticipantFrequency Modulation Continuous wave (FMCW) is a leading technology in the field of optical LiDAR. FMCW LiDAR offers several advantages, such as improved range resolution, better dynamic range, and the ability to measure both speed and distance simultaneously. In this example, we will demonstrate a LiDAR system using INTERCONNECT, incorporating a FMCW laser source with homodyne detection to measure both distance and speed of a moving object.
Read the full article here: https://optics.ansys.com/hc/en-us/articles/40617631207955
- Spontaneous Parametric Down-Conversion (SPDC) Photon Source
- Spontaneous Four-Wave Mixing (SFWM) Microring Resonator Photon Source
- Multi-Mode Interference (MMI) Coupler
- Photonic Crystal Slab (RCWA)
- Traveling Wave Mach-Zehnder Modulator
- Calculation of SPAD Photon Detection Efficiency
- Small-Scale Metalens – Field Propagation
- Diffraction-Based Overlay Metrology System Design
- Ring Modulator
- Integrated microlens and grating coupler for photonic integrated circuits
