June 5, 2023 at 7:05 am
FAQParticipantThis error is mainly faced by ANSYS Electronics (Ansoft) users. If you are seeing this error, check these; 1. TECS date of installed ANSYS Electronics license is up to date to support the version of ANSYS Electronics (Ansoft) used. 2. ANSYS License Manager is updated to support the version of ANSYS Electronics (Ansoft) used. 3. Ansoft license (ansoftd.lic) is properly installed. It should use ansyslmd in place of ansoftd as shown in the example below. #SERVER licenseservername 12ab34cd56ef SERVER licenseservername 12ab34cd56ef 1055 #VENDOR ansoftd VENDOR ansyslmd USE_SERVER
