May 22, 2023 at 9:23 am
FAQParticipantIn January 2023 an issue with subscription licensing arose that prevented license authentication. When using subscription licensing after this date the software will be prevented from renewing its authentication. Without the ability to authenticate, the software will not be able to run and will prompt the user with this error message:
Affected products:
Ansys Discovery Simulation (Named User), all versions
Ansys Discovery Modeling (Named User), all versions
Ansys SpaceClaim (Named User), all versions
Steps to fix:
1. Download patch located here (includes patch for versions 2021 R1 through 2023 R1)
2. Unzip contents of downloaded zip file
3. Double click on the executable and install the patch (you may need to right click and run as administrator)
4. Launch Discovery or SpaceClaim and enter your login information
After installing this patch, the software will be able to properly authenticate the next time you launch the product. If it still isn’t working for any reason please create a post requesting additional information.
May 22, 2023 at 9:27 am
Anuja Burambadkar
ParticipantRichard Nichols I got the same massage first time, then i closed it. Then right click the setup, and pressed run as administrator and then it worked.
May 22, 2023 at 9:29 am
Anuja Burambadkar
ParticipantThat got it to work… many thanks! I’m in…
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- Discovery Subscription license – Command line options
- ANSYS Discovery: Compatibility Utility
