Is there any naming convention for the DPM injection as a placeholder for particles stripped away from an Eulerian Wall Film?
June 6, 2022 at 8:33 am
FAQParticipantYes, the name of the film material and the injection material should “match” in some way. There are 2 possibilities:
1.The injection dpm material name is part of the film material name.
2.The film material name is contained in the injection dpm material name.
Example of #2: If the name of the (Eulerian) film material is “my-film-liquid”) give the material for the stripped / separated particles a name that contains the complete name of the film material (e.g. “my-film-liquid-dpm”).
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
