Is there any example to understand how to the predict the fatigue life of a structure subjected to both Static (Mean) plus Random vibration loads using Ansys nCode Deign Life ? Keywords : Mean Stress, nCode , Static + Random
Tagged: 2020 R2, Ansys nCode DesignLife, General, structural-mechanics
May 15, 2023 at 8:32 amSolutionParticipant
Refer attached WB example. Ansys nCode Design life must be installed along with WB to open this project.
1. 2065186.zip
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
