Is there any example for rotation system (shaft) vibro acoustics noise assessment example ? Acoustics ,rotating shaft, casing Nosie
Tagged: 18.2, acoustics, mechanical, structural-mechanics
March 17, 2023 at 1:11 pmSolutionParticipant
Refer attachment for solution.
1. 2063160.zip
2. Acoustics Casing Shaft Harmonic one Way.pdf
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
