Tagged: 18, General, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantYes, there is a Ansys Viewer, that enables you to visualize, interpret and compare ANSYS simulation results right in your web browser. . It helps improve collaboration with colleagues and customers, and provides a way to quickly relay simulation intent and results to your extended design team. Any stakeholder can use the viewer to open ANSYS Viewer (.avz) files that have been exported from ANSYS CFX-Pre, CFD-Post, TurboGrid, and ANSYS Mechanical. The viewer’s simple yet powerful features make it easy to review, share and analyze design information, pinpoint issues, suggest improvements, get approvals, and make optimal design decisions. Previous experience with ANSYS simulation software is not required. With ANSYS Viewer you can: Zoom, pan and rotate in 3-D Create cross-sections Explode a multi-part model Highlight, show and hide individual parts Annotate in 2-D and 3-D Save and reload views Play a sequence of images It can be downloaded here : http://www.ansys.com/products/platform/ansys-viewer
