June 6, 2022 at 9:58 am
FAQParticipantOne can issue the command ERESX,NO in /PREP7 prior to solving then use PRESOL command to output unaveraged element results. This will give the integration point values for those integration points nearest to the node location. Also one may use the INISTATE command for the same.
Following is the Syntax of the command to be used:
INISTATE, WRITE, FLAG, , , , CSID, Dtype
