Is there a way to import the gas-liquid interface obtained from a Fluent VOF simulation to a pre-processor (e.g. SpaceClaim) as a surface?
January 25, 2023 at 7:17 am
FAQParticipantIt is possible to export the VOF iso-surface as an STL from either CFDPost or Fluent directly and this STL file can be imported into SpaceClaim. Once the STL file is loaded into SpaceClaim, reverse engineering tools can be used to manipulate the STL to create a surface.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
