Is there a way to create ‘Thickness’ of a group of sheets with uniform thickness as a single parameter
Tagged: 2019 R2, design-exploration, General, Workflow Technologies
March 17, 2023 at 2:15 pm
FAQParticipantWe can use thickness option available under geometry to define uniform thickness to group of surface bodies and assign it as a parameter. We can also define idividual surface thickness as parameter in Mechanical and in DX, we can maintain one parameter of the group as master and replace expression for other parameters of the group to master parameter name. It will help in controlling parameter value of other parameters of the group.
