Tagged: 17.2, fluent, fluid-dynamics, MP - Free Surface Flow, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQParticipantIn the Fluent solidification & melting model, the liquid fraction can be accessed in the udf using the following macro: C_LIQF(c,t) c, t is the following variables, respectively: cell_t: c Thread: *t C_LIQF is available only in fluid cells and only if solidification is turned ON
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
